QuanH
Dec 16, 2021Aspirant
r6400v2 and CM700
Hi Guys I have some problem with internet , so I just unplug the ethenet cable from my modem and plug it back to router after firmware updated and then it not show me the wifi connect anymore, but it...
Dec 16, 2021Guru - Experienced User
Power OFF the 6400 router then back ON?
Be sure the wifi radio button is pressed to enable the wifi radios on the router.
Try a factory reset and setup from scratch on the router.
- QuanHDec 16, 2021Aspirant
thank you so much
the radio button is turned off and I just fix it- FURRYe38Dec 16, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
