QuanH
Dec 16, 2021Aspirant
r6400v2 and CM700
Hi Guys I have some problem with internet , so I just unplug the ethenet cable from my modem and plug it back to router after firmware updated and then it not show me the wifi connect anymore, but it...
QuanH
thank you so much
the radio button is turned off and I just fix it
Dec 16, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
