LP128
Sep 19, 2019Tutor
R6400v2 bricked after firmware update
I clicked the update firmware button on routerlogin.net, waited about 30 minutes, and nothing happened. Now my router's power button just flashes red. I downloaded the latest firmware and tried to ...
- Sep 20, 2019
I got it to work using a different tool: https://github.com/jclehner/nmrpflash
I downloaded the oldest version of my router's firmware (R6400v2-V1.0.2.14_1.0.7.chk) from https://www.netgear.com/support/download/ into the same download location as nmrpflash.
I unplugged the router's WAN and plugged my computer into the router's LAN port #1.Opened Control Panel\Network and Internet\Network Connections
right clicked "Ethernet"
clicked "Properties"
double clicked Internet Protocol Version 4 (TCP/IPv4)switched to a static IP address:
IP Address: 192.168.1.10
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.1I opened a command prompt as administrator, and changed to my download directory for nmrpflash:
cd C:\Users\LP128\Downloadsthen typed the following to view a list of my network connections (I typed the command as shown, without a preceding pound sign):
nmrpflash -LIt showed that 192.168.1.10 (Ethernet) was the net2 connection
Then I turned off my router, and typed the following without pressing enter:
nmrpflash -a 192.168.1.1 -i net2 -f R6400v2-V1.0.2.14_1.0.7.chkI pressed enter, and immediately turned on my router. I had to try four times before I got the timing correct.
When the it worked successfully, the command prompt displayed this:
Advertising NMRP server on net2 ... \
Received TFTP_UL_REQ while waiting for CONF_REQ!
Received upload request without filename.
Uploading R6400v2-V1.0.2.14_1.0.7.chk ... OK
Waiting for remote to respond.
Received keep-alive request.
Remote finished. Closing connection.
Reboot your device now.("Received keep-alive request." was actually repeated 26 times. I shortened it here.)
I rebooted the router, and after a couple of minutes the power indicator turned white.
I plugged the WAN back into the router.
I went back to my computer's ethernet properties and changed the IP address back to automatic.
Downloaded the latest firmware from https://www.netgear.com/support/download/
Went to routerlogin.net, and upgraded the firmware to this latest version under Advanced - Administration - Router Update
antinode
Sep 19, 2019Guru
> I'm using Windows 10. [...]
Thanks for the details. That all looks plausible to me, right down
to the byte count, assuming that the router really is a R6400v2. (And
I'm willing to believe that you can read the product label.)
I might try it with a less elaborate start sequence. For example,
ignore the Reset button, and just apply power.
> [...] I waited over 30 minutes. [...]
After the transfer, the LEDs should do different things, and, within
a few minutes, a normal start-up should follow.
LP128
Sep 20, 2019Tutor
nmrpflash -L
