nh867
Oct 12, 2021Tutor
R6400v2 DNS Issues
My last internet provider required a wireless gateway, so I didn't need to use my R6400v2 for about a year. I just pulled it out again and did a factory reset. In the process it upgraded to the lates...
Oct 12, 2021Guru - Experienced User
Seen this after you edited. Let us know if that doesn't help with the dns issue
- nh867Oct 12, 2021Tutor
Thank you. So far this firmware version works perfectly fine, no more DNS issues. Hopefully Netgear releases a fixed firmware for anyone else who is experiencing the issue, it was infuriating to troubleshoot.
- plemansOct 12, 2021Guru - Experienced User
We even struggled on here. And the problem is that its across multiple product lines. There's been a lot of downgrading lately so I'm hoping they're working on it!
