nh867
Oct 12, 2021Tutor
R6400v2 DNS Issues
My last internet provider required a wireless gateway, so I didn't need to use my R6400v2 for about a year. I just pulled it out again and did a factory reset. In the process it upgraded to the lates...
Oct 12, 2021Guru - Experienced User
Seen this after you edited. Let us know if that doesn't help with the dns issue
nh867
Oct 12, 2021Tutor
Thank you. So far this firmware version works perfectly fine, no more DNS issues. Hopefully Netgear releases a fixed firmware for anyone else who is experiencing the issue, it was infuriating to troubleshoot.
- plemansOct 12, 2021Guru - Experienced User
We even struggled on here. And the problem is that its across multiple product lines. There's been a lot of downgrading lately so I'm hoping they're working on it!
