nh867
Oct 12, 2021Tutor
R6400v2 DNS Issues
My last internet provider required a wireless gateway, so I didn't need to use my R6400v2 for about a year. I just pulled it out again and did a factory reset. In the process it upgraded to the lates...
RushMan2112
Oct 12, 2021Initiate
I have a Nighthawk R8000P that autoupdated to the newest firmware (V1.4.2.84_1.3.42). I have had nothing but DNS issues since the "upgrade". I just rolled back to the previous firmware (V1.4.1.68_1.3.28) and DNS problems all gone.
Oct 12, 2021Guru - Experienced User
RushMan2112 are you using IPv6?
- RushMan2112Oct 13, 2021Initiate
I am. I changed the IPv6 settings to AUTO and went to an IPv6 test site. My tests all passed so I did the firmware update again. Everything seems to be working fine now.
Thanks for pointing me in the right direction.
- plemansOct 13, 2021Guru - Experienced User
Glad to help!
- hansp22Dec 30, 2021Aspirant
I am having similar issues with my R6400v2 running firmware V1.0.4.120_10.0.91. The router responds to many DNS requests with REFUSED. The behaviour is independent of the configured DNS server (tried both my ISPs DNS server and Cloudflares 1.1.1.1) and affects both wired and wireless connections, although the rate of REFUSE responses was higher for wired connections. A workaround was to configure my client PCs to directly use the external DNS server rather than query the router.
Finally I downgraded the router firmware to V1.0.4.106_10.0.80 which resolved the problem for now.
I hope that Netgear will address this issue in a future firmware update for the R6400v2.
