AllForPun
Jun 22, 2020Aspirant
R6400V2 failed firmware
Ok all, I was recently (today) upgrading my frimware for the R6400v2 through the router's web portal. While uploading the firmware, it failed. No idea why it failed, but it did. Suddenly, I l...
- Jun 23, 2020
> [...] what appears to be a cycle [...]
In some cases, the router can get into a (failing) boot loop, which
might mean that if it's ever receptive to a TFTP load, then you might
need to catch it at the right time. Some experimentation may be needed.> [...] (see attached).
You're running the "tftp" program, and then giving _it_ a command to
run the "tftp" program.> [...] But the "$" int he above is what confuses me.
What was on the line before what you posted? That "$" was supposed
to represent (abbreviated) the prompt from your shell (which, as your
"ping" picture showed, is pretty long, but does end in "$ ").So, the actual command should look like:
<blah-blah-blah> $ tftp 192.168.1.1of which you type only: tftp 192.168.1.1
The "tftp" program uses a "tftp> " prompt, and you type whatever
appears after that in the example.> [...] I'm sorry, I'm a bit novice at this. [...]
I noticed. Just bask in the education. Wheee.
> [...] I already did the /usr/bin/tftp bit to access the tftp.
That was what the "tftp 192.168.1.1" command was for. You could,
instead, do:$ tftp
tftp> connect 192.168.1.1which would be equivalent to (but more work than):
$ tftp 192.168.1.1
The "put fred.img" command assumes that your firmware image file (use
its actual name) is in the shell's current directory. Otherwise, you'd
need to specify an appropriate path to it (like the one (partially)
shown in your Tftpd64 screen shot, but with a Mac/unix syntax instead of
a PC\Windows syntax). For some shell navigation basics, see, for
example:
antinode
Jun 22, 2020Guru
> [...] I was going to follow the guides to upload the firmware through
> a TFTP, but my computer no longer has an ethernet port (macbook pro,
> late 2013 model). [...]
You need older/better junk. Or a USB-Ethernet adapter. Or a
better-equipped friend.
> [...] the TFTP program suggested for mac users is a 32bit, [...]
There's no need for any third-party TFTP client program. The
command-line programs which come with any popular OS generally provide
better error messages, too. See, for example:
https://community.netgear.com/t5/x/x/m-p/1622096#M102004
> [...] factory reset, it does nothing! The power LED continues to blink
> amber [...]
The flashing Power indicator means that the firmware is corrupt, and,
without working firmware, even basic router features like a settings
reset can't work.
The TFTP recovery procedure is the usual tool for loading firmware
into a (mostly) helpless device.
AllForPun
Jun 23, 2020Aspirant
> "The command-line programs which come with any popular OS generally provide better error messages, too."
The link you provided me has links which provide instructions on using the TFTP programs, but you mentioned bening able to use the command-line programs with my OS. Do you have a guide for just that?
