Fleming55
Nov 07, 2021Aspirant
R6400v2 firmware check error
When attempting to update firmware I get a message the the firmware check had an error. I select try again, but get the same error. Current firmware is V1.0.106_10.0.80
Trailboss60
Jan 21, 2022Aspirant
Same problem on 1/21/2022 Since netgear has not provided any advice, I guess they have no solution....rebooted the router and WIFI, did not make a difference.
- FURRYe38Jan 21, 2022Guru - Experienced User
One can manually update FW as well by checking NG download site for updates and manually installing:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Netgear has set up a community forum specifically for Smart WiFi Router products:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thank you
