andresbarrones
Oct 03, 2021Aspirant
R6400v2 firmware corrupted
Hi I have a problem with my R6400v2 router. I tried to install the TomatoFirmware firmware but it seems that there has been a failure in the installation and the system has been corrupted. The route...
- Oct 03, 2021
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
If that doesn't work, check on the tomato forums as they'll be more familar with undoing what their firmware did.
andresbarrones
ok but do you have any idea how to repair the device?
Oct 03, 2021Guru - Experienced User
