JDCDR
Sep 27, 2021Follower
R6400v2 Firmware Version 1.0.4.1.120
This firmware has caused the same issue as described in the following discussion: https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/This-Site-Can-t-Be-Reached-issue/m-p/2132332#M2115...
Sep 27, 2021Guru - Experienced User
quite a few posts on this issue across multiple product lines.
Thanks for posting.
Hopefully the more posts, the more mods that see it and direct the engineering teams at it
