JDCDR
Sep 27, 2021Follower
R6400v2 Firmware Version 1.0.4.1.120
This firmware has caused the same issue as described in the following discussion: https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/This-Site-Can-t-Be-Reached-issue/m-p/2132332#M2115...
Sep 27, 2021Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Good Luck.
The symptom is that you get a page "This site can't be reached", then it will try to reload the page and is usually successful. Some times you have to manually reload the page for it to load.
This needs to be addressed as soon as possible. It would be appreciated to get a reply when this issue has been acknowledged and corrected. In the meantime, I'm downgrading to version 1.0.4.106, which was working properly.
Thank you.
