JDCDR
Sep 27, 2021Follower
R6400v2 Firmware Version 1.0.4.1.120
This firmware has caused the same issue as described in the following discussion: https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/This-Site-Can-t-Be-Reached-issue/m-p/2132332#M2115...
Retired_Member
Sep 27, 2021Same issues. I downgraded back to V1.0.4.106_10.0.80 since the latest firmware as of this writing was causing the timeout issues as many have mentioned. According to my family the internet went out a couple of times.
I complained to Netgear about it on Twitter and after a couple of days they responded that they wanted to contact me about the issue. Well, considering that I mentioned that there's posts in the community forum, honestly they could just check here instead.
I plan to go back to ASUS when I get the funds to replace this router.
