Retired_Member
Sep 30, 2021R6400v2 Firmware Version 1.0.4.118 and 1.0.4.120
We've been having the same issue that's been reported about browsing the web and running into the message "This site cannot be reached" DNS issue when I updated to R6400v2 Firmware Version 1.0.4.118 ...
- Oct 01, 2021
Thanks for posting. The more that are on here with that issue, the more likely the mod's/engineers will see it.
Retired_Member
Oct 02, 2021You're welcome! I tried contacting support directly, but after entering in my serial number, my 90 day window of complimentary support is over and unfortunately there is no other way of sending them a bug report.
Wife and daughter mentioned that they had to restart the router a couple times during the following day I upgraded to the 120 version of the firmware due to the internet going out, but I wasn't home so I can't say exactly what went out; WiFi, Ethernet, or both.
DandyMan
Oct 08, 2021Tutor
I can also confirm I am seeing internet outages on certain devices with the 118 and 120 updates. Rolling back to 106 seems to fix this. I am using the Circle parental controls.
- FURRYe38Oct 08, 2021Guru - Experienced User
Do you happen to perform a factory reset after v120 was applied and setup from scratch to see if problem still appeared?
- DandyManOct 08, 2021Tutor
No factory reset performed. If someone can confirm that reset resolves this problem I will try it.
If I have to set up from scratch, it would be less wasteful of my time to use a known working router.
Well resets are a valid troubleshooting step to see if it resolves issues after FW updates. Seen many issues resolved after FW updates.
Users choice though.
Good Luck.
