Retired_Member
Sep 30, 2021R6400v2 Firmware Version 1.0.4.118 and 1.0.4.120
We've been having the same issue that's been reported about browsing the web and running into the message "This site cannot be reached" DNS issue when I updated to R6400v2 Firmware Version 1.0.4.118 ...
- Oct 01, 2021
Thanks for posting. The more that are on here with that issue, the more likely the mod's/engineers will see it.
DandyMan
Oct 08, 2021Tutor
No factory reset performed. If someone can confirm that reset resolves this problem I will try it.
If I have to set up from scratch, it would be less wasteful of my time to use a known working router.
Oct 08, 2021Guru - Experienced User
Well resets are a valid troubleshooting step to see if it resolves issues after FW updates. Seen many issues resolved after FW updates.
Users choice though.
Good Luck.
