Retired_Member
Sep 30, 2021R6400v2 Firmware Version 1.0.4.118 and 1.0.4.120
We've been having the same issue that's been reported about browsing the web and running into the message "This site cannot be reached" DNS issue when I updated to R6400v2 Firmware Version 1.0.4.118 ...
- Oct 01, 2021
Thanks for posting. The more that are on here with that issue, the more likely the mod's/engineers will see it.
DandyMan
Nov 04, 2021Tutor
I can confirm that doing the factory reset after the firmware update (1.0.4.120) resolved my issues.
Nov 04, 2021Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
