OmgMav
Oct 21, 2021Aspirant
R6400v2 in bridge mode having issues with R6080 as primary connected to modem
Hello, I'm having a very difficult time with trying to set up my R6400v2 in Bridge Mode, connecting it wirelessly to the R6080, which is connected to my cable modem. The short story is that it woul...
- Oct 22, 2021
Netgear has set up a community forum specifically for General Router products. Most of the people who watch that forum are more likely to have experience with older routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-generalPlease use this link to the main forum product list to review and choose where to make your posts.
Thank you
Oct 22, 2021Guru - Experienced User
Thank you
OmgMav
Oct 22, 2021Aspirant
FURRYe38 wrote:Netgear has set up a community forum specifically for General Router products. Most of the people who watch that forum are more likely to have experience with older routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
Thank you
Thank you for your response. I have copied the post to the appropriate forum.
- FURRYe38Oct 22, 2021Guru - Experienced User
