CMT1812
May 18, 2020Aspirant
R6400v2 Internet light is solid amber
Hi - I have been trying to connect my R6400v2 router to the modem. Once connected, the internet light stays amber. I have downloaded the newest firmware, and run numerous tests and fixes to see if I c...
- May 20, 2020
CMT1812 wrote:
From there I was given the TP Link modem/router by my ISP (TPG) which they connected to the nbn modem.That is probably the issue.
TPG has some strange settings.
Search - NETGEAR Communities – TPG NBN
Solved: Re: VLAN tagging for TPG NBN - NETGEAR Communities
The moral of this story is that it helps to explain things in detail from the outset.
CMT1812
May 19, 2020Aspirant
Yes I have downgraded it to the firmware you stated. The modem is definitely working because when I plug the router in that was given from ISP, the internet works
