CMT1812
May 18, 2020Aspirant
R6400v2 Internet light is solid amber
Hi - I have been trying to connect my R6400v2 router to the modem. Once connected, the internet light stays amber. I have downloaded the newest firmware, and run numerous tests and fixes to see if I c...
- May 20, 2020
CMT1812 wrote:
From there I was given the TP Link modem/router by my ISP (TPG) which they connected to the nbn modem.That is probably the issue.
TPG has some strange settings.
Search - NETGEAR Communities – TPG NBN
Solved: Re: VLAN tagging for TPG NBN - NETGEAR Communities
The moral of this story is that it helps to explain things in detail from the outset.
CMT1812
May 20, 2020Aspirant
Ok so I have HFC nbn. The arris is provided by NBN, and connects to the wall.
TPG provides the internet and that’s all.
michaelkenward
May 20, 2020Guru - Experienced User
- CMT1812May 20, 2020AspirantYou’re a legend mate. Thanks so much. Worked straight away. And apologies about the poor explanation, felt like I had tried everything so was close to giving up. Cheers
- michaelkenwardMay 20, 2020Guru - Experienced User
NBN is a dog's dinner. It appears here often.
This place might be useful if you hit more brick walls:
Another victim posted it a whole back. Apparently, your ISP is hopeless at support.
