mdecaro
Jan 21, 2022Aspirant
R6400V2 REMOTE MANAGEMENT STOPPED WORKING
I have the above router and remote management is enabled both through the router itself at port 8443 and the Nighthawk App. It will work for a week or so, and then stops working. I tried rebooting...
mdecaro
I posted to the Nighthawk Routers section??
I had done a factory reset and restart. I lose access regularly. The real problem isn't that I can't access the router, every week I lose outside access to the home network so I cannot use my Nest thermostat. If I go there and reset the modem, it starts working again for a week, so I started remotely rebooting daily, and that prolonged the time to loss of the network, but didn't fix it. The same thing happened to the R7000 I had as I noted.
That router is 60 miles away from my primary house, and I want to adjust the thermostst before I go!!!
Jan 21, 2022Guru - Experienced User
The 6400 series router is a Smart WiFi Router, not NightHawk.
- mdecaroJan 21, 2022Aspirant
OK thx.
It is an Arris SB6141 cable modem, on Xfinity.
- FURRYe38Jan 21, 2022Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Those these apply to NG modems, you might have the ISP review your modem to ensure it's working to the modem and ISP specs:
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
The firmware last showing in the Nighthawk app is V1.0.4.122
I did that last summer, and it did not fix the issue. The cable modem is right where the cable enters the house, and I do not have TV so it is the first connection.
Since the same think occurred in two locations in different states with Nethgear modems, I am skeptical it is a signal problem????
You might revert back to older FW and see. Were seeing lots of problems with recent FW versions across different router lines.
I'd go back to maybe first verion and see if it stablized or if you know what had worked before, go back to that version.
As a suggestion to get around using Remote Management on the router, if you have PC at the remote location, install TeamViewer on this PC. Then you can connect to this PC from your location using a PC and TeamViewer and log in to the router that way. As long as the ISP serivce, modem and router and PC is working you can manage the router that way.
- michaelkenwardJan 22, 2022Guru - Experienced User
Which makes no difference.
