mdecaro
Jan 21, 2022Aspirant
R6400V2 REMOTE MANAGEMENT STOPPED WORKING
I have the above router and remote management is enabled both through the router itself at port 8443 and the Nighthawk App. It will work for a week or so, and then stops working. I tried rebooting...
michaelkenward
Jan 22, 2022Guru - Experienced User
Are you using Anywhere Access? (It was calked Remote Access.)
Have you caught up with the changes to Netgear's cloud services?
- mdecaroJan 27, 2022Aspirant
I have activated access from the nighthawk app (ios) as well as remote management (https://xxx.xxx.xxx:8443). No luck either way.
What cloud changes?
- xaceproJan 27, 2022Aspirant
Enablign anywhere access only allows you to connect to the router remotely with the NIghthawk app. There is no remote browser access anymore. Mobile app is useless if you want to do anything advanced with the router.
