ktyson068
Jan 22, 2021Aspirant
r6400v2 UPNP issues?
I have 2 xbox's connected through hardwire to my r6400v2 they have issues playing the same game together at the same time. My router is on its most recent firmware update, I did a factory reset earli...
DarrenM
Jan 29, 2021Sr. NETGEAR Moderator
You could try putting the xbox in the DMZ
https://kb.netgear.com/1118/How-do-I-configure-a-device-to-be-in-the-DMZ-on-my-NETGEAR-router
DarrenM
ktyson068
Jan 29, 2021Aspirant
I ended up using static IPs and port forwarding 3074 and one of the alternates. That seems to have done the trick. I think the actual issue is the firewall in the modem and my ISP has locked me out of adjusting the settings for that. Thank you for reaching out with that.
