ensign_redshirt
May 10, 2018Tutor
R6700 1.0.1.46 breaks UPnP?
Upgraded to 1.0.1.46 last night. Had an issue streaming with Plex this morning (access held fine for 2-3 songs then died completely). Plex remote access then became completely inaccessible, in additi...
- Jun 07, 2018
Hi All,
A new firmware update is available. Please update the firmware to 1.0.1.48.
https://kb.netgear.com/000059128/R6700-Firmware-Version-1-0-1-48
Blanca
Community Team
michaelkenward
May 11, 2018Guru - Experienced User
ensign_redshirt wrote:
- I did not try a factory reset after upgrading as some threads suggest.
Not just "some threads", also Netgear support. (Pity they don't make this clearer in the Release Notes.) No one is going to put much effort into this discussion if you don't try that.
I guess I'll wait for whatever is after 1.0.1.46 to try again and/or until I have more time to try a factory reset and restore.
I don't know what you mean by "restore". If you intend to restore from a saved backup of your settings, that can be a good way of reviving whatever it is that is causing your problems.
After a reset you should reconfigure, not restore, the settings.
