ensign_redshirt
May 10, 2018Tutor
R6700 1.0.1.46 breaks UPnP?
Upgraded to 1.0.1.46 last night. Had an issue streaming with Plex this morning (access held fine for 2-3 songs then died completely). Plex remote access then became completely inaccessible, in additi...
- Jun 07, 2018
Hi All,
A new firmware update is available. Please update the firmware to 1.0.1.48.
https://kb.netgear.com/000059128/R6700-Firmware-Version-1-0-1-48
Blanca
Community Team
Santerianumero1
Jun 04, 2018Guide
Experiencing the exact same issue after sw update. My cameras are no longer working and upnp is a blank page even though it's enabled.
- michaelkenwardJun 04, 2018Guru - Experienced User
Santerianumero1 wrote:
Experiencing the exact same issue after sw update. My cameras are no longer working and upnp is a blank page even though it's enabled.I assume that you did the factory reset thing. The Netgear people will ask you to do that before they take the problem any further.
- Santerianumero1Jun 04, 2018GuideCorrect, however; "the Netgear people" have never reached out. Netgear has some of the most pisspoor support out there. I got this pile (r6700) at Costco and it wasn't even in the support materials until a couple of YEARS after it was launched. Every sw update is an adventure to say the least. Thankfully this isn't a catastrophic stop for me but more of a damn annoyance.
- Blanca_OJun 07, 2018NETGEAR Employee Retired
Hi All,
Blanca
Community Team
