ensign_redshirt
May 10, 2018Tutor
R6700 1.0.1.46 breaks UPnP?
Upgraded to 1.0.1.46 last night. Had an issue streaming with Plex this morning (access held fine for 2-3 songs then died completely). Plex remote access then became completely inaccessible, in additi...
- Jun 07, 2018
Hi All,
A new firmware update is available. Please update the firmware to 1.0.1.48.
https://kb.netgear.com/000059128/R6700-Firmware-Version-1-0-1-48
Blanca
Community Team
ensign_redshirt
Jun 07, 2018Tutor
So far so good, although I only upgraded a few moments ago. The issue didn't present itself immediately last time though (took ~8-12hrs and died in the middle of an active streaming session) so I'm going to monitor for a couple of days before calling it good. Thanks for the update!
ensign_redshirt
Jun 09, 2018Tutor
Coming up on 48hrs and things have been pretty clean. I had a monitoring service that was a little unhappy for a few hours after the upgrade, but a restart of that system seems to have re-established itself and everything has been quiet (from an alerting perspective).
Thanks for the update. It appears to have addressed the initial issue without needing to reset/re-enter any settings.
