maybenotstig
Nov 11, 2020Guide
R6700 5G Connection Is Missing
My R6700 has always put out a 2G and 5G wifi connection until yesterday. 5G is no longer appearing in the list of available networks on any devices that had previously been connected to it. I updated...
- Nov 15, 2020
Bought another router from another company with 2 years of technical support for almost half the price and better performance than the R6700. I have a 5G connection again with this new router.
Thank you for absolutely nothing Netgear, aside from encouraging me to explore other router manufacturers.
maybenotstig
Nov 11, 2020Guide
I don't see this option, where does it live?
Nov 11, 2020Guru - Experienced User
My bad. I thought the R6700v3 had the option. it doesn't. My bad.
Does your status page show it online?
Did the ssid broadcast get disabled?
Or the 5ghz radio get disabled?
- maybenotstigNov 11, 2020Guide
Status shows the 5G channel is online.
SSID broadcast is enabled.
Radio is enabled.
- plemansNov 11, 2020Guru - Experienced User
have you checked with a a different device? maybe its a device specific issue?
Have you used a wireless scanner like inssider or acrylic to check the broadcast?
Have you tried renaming the 5ghz connection?
Yes, 5G is no longer an option from any devices that were connected to it last week.
Yes, the scanner does not find the 5G channel either.
Yes.
