maybenotstig
Nov 11, 2020Guide
R6700 5G Connection Is Missing
My R6700 has always put out a 2G and 5G wifi connection until yesterday. 5G is no longer appearing in the list of available networks on any devices that had previously been connected to it. I updated...
- Nov 15, 2020
Bought another router from another company with 2 years of technical support for almost half the price and better performance than the R6700. I have a 5G connection again with this new router.
Thank you for absolutely nothing Netgear, aside from encouraging me to explore other router manufacturers.
mshakr
Nov 19, 2020Aspirant
Wow! I am having the exact same issue on my R7000P Nighthawk router and also Netgear wouldn't help me over the phone because I purchased it over 3 months ago even though it is still covered by a hardware warrantee!! I already tried doing a reset to factory default as well as a firmware upgrade and downgrade and nothing fixes it. I noticed a few other people had a similar issue without a real solution to the problem. It's obviously a router issue and most probably hardware related.I have never seen this type of support any where else. This was my first Netgear router purchase and definitely my last! It's so frustrating!
