AM_R6700_AC1750
Jan 18, 2021Guide
R6700 AC1750 router does not allow Gigabit connections?
I just upgraded my cable Modem to a Netgear CM1100 that supports Gigabit connections. I have an R6700/Nighthawk AC1750 Smart WiFi router connected to it. My wireless speeds and wired Ethernet connect...
- Jan 19, 2021
The R6700 is gigabit capable.
What firmware is on it?
Did you ever try a factory reset on it with a clean install (not from backup)? sometimes old qos settings can cause issues.
have you tried replacing the cable?
Also, make sure you're speedtesting over a hardwired connection. wireless AC won't hit gigabit speeds wireless. Especially the 2.4ghz.
AM_R6700_AC1750
Jan 19, 2021Guide
As suggested by plemans , I reset my router and now I get way more bandwidth than 80 Mbps like I did before.
But resetting came up with just 2 wireless SSIDs. And the Guest radios are disabled.
I'll try activating them again and report back.
A follow-up question: will re-activating the bonding of the 2.4 and 5 GHz bands for QoS mess up the accessible bandwidths again?
schumaku
Jan 20, 2021Guru - Experienced User
AM_R6700_AC1750 wrote:A follow-up question: will re-activating the bonding of the 2.4 and 5 GHz bands for QoS mess up the accessible bandwidths again?
This not bonding (link aggregation, LAG, ...) of the the wireless radios. Having the same SSID for all radios - what makes perfectly sense as an SSID does designate an access to one network - will allow the mobile clients using the best available connection, assisted by some basic mesh standard features. where the 5 GHz will perform well, it's very likely the clients use the fast 5 GHz radio. Where the 5 GHz signal is becoming weak, the clients can almost seamlessly change to 2.4 GHz radio - what is slower but has offers the better coverage.
- AM_R6700_AC1750Jan 21, 2021Guide
I think the "SmartConnect" option for wireless does what you described. I enabled that to use just a single SSID and automatic selection of band when connecting devices.
But I notice that there is another option in the router regarding "QoS." My question relates to that. I believe I have that enabled when I was having problems of getting >100 Mpbs even for wire connections. And I think plemans was referring to it when he suggested I reset my router.
On another topic, I enabled the "Guest" radios. That did not affect the download speeds (which may be as expected).
I did both wired and wiless connections before and after resetting my router. Before resetting, speeds for both were below 100Mbps. After resetting the wired connection went as high as 850Mbps and the wireless as high as 360 Mbps.
- plemansJan 21, 2021Guru - Experienced User
360mbps is about what you can expect out of the wireless on the R6700. You won't hit gigabit over wireless on an AC device.
