Xaxinian
Aug 01, 2017Follower
r6700 amber light smart tv
I just purchased this router and have 3 units hardwired into it. My pc, ps4 and my new Amazon fire Tv. Its an actual smart tv not tbe box or stick. The corresponding lights show white for the pc and p...
- Aug 15, 2017
Hi Xaxinian,
Check the ethernet cable if it supports Gigabit.
Change ports.
Connect the PC to the port that shows amber if it is amber.
If the port, whatever port the TV is connected, still shows amber, you need to check with the TV to make sure the port is on Gigabit mode.
JamesGL
Aug 15, 2017NETGEAR Employee Retired
Hi Xaxinian,
Change ports.
JamesGL
Aug 20, 2017NETGEAR Employee Retired
Hi Xaxinian,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
