Santerianumero1
Jan 09, 2017Guide
R6700 Android VPN
I'm wondering why the KB article says it encompasses the R6700 but I still can't use my android with VPN and this router? I've tweeted you with no response either. Please help. https://twitter.com/...
- Feb 28, 2017
Hi Santerianumero1,
Can you check on the OpenVPN tab. There should be an option for Mobile OpenVPN using the latest firmware.
Santerianumero1
Jan 21, 2017Guide
I appreciate your response. It's so far the best responsiveness I've had from Netgear. I know obviously you cannot divulge dates or whether it's happening or not but, can you tell me if it's happening or not lol? Is the r6700 going to get android VPN functionality like the r7000 just got?
- JamesGLJan 22, 2017NETGEAR Employee Retired
Hi Santerianumero1,
Let me check on this inquiry.- JamesGLFeb 28, 2017NETGEAR Employee Retired
Hi Santerianumero1,
Can you check on the OpenVPN tab. There should be an option for Mobile OpenVPN using the latest firmware.- JamesGLMar 05, 2017NETGEAR Employee Retired
Hi Santerianumero1,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- storm1985Mar 05, 2017Prodigy
JamesGL if R6700 already support iOS or Android VPN client software can I request the following:
1. Update on the release notes of the firmware version that supports it. I cant see this on latest fw 1.0.1.16
2. R6700 manual update on page 169 which states it does not support mobile VPN.
These are only my suggestions. :)
Thanks.
- JamesGLMar 09, 2017NETGEAR Employee Retired
Hi storm1985,
Checking with the team on your suggestions. Thank you for that. :)
Hi Santerianumero1,
You are welcome. :)
