Santerianumero1
Jan 09, 2017Guide
R6700 Android VPN
I'm wondering why the KB article says it encompasses the R6700 but I still can't use my android with VPN and this router? I've tweeted you with no response either. Please help. https://twitter.com/...
- Feb 28, 2017
Hi Santerianumero1,
Can you check on the OpenVPN tab. There should be an option for Mobile OpenVPN using the latest firmware.
Santerianumero1
Jan 21, 2017Guide
I appreciate your response. It's so far the best responsiveness I've had from Netgear. I know obviously you cannot divulge dates or whether it's happening or not but, can you tell me if it's happening or not lol? Is the r6700 going to get android VPN functionality like the r7000 just got?
JamesGL
Jan 22, 2017NETGEAR Employee Retired
Hi Santerianumero1,
Let me check on this inquiry.
- JamesGLFeb 28, 2017NETGEAR Employee Retired
Hi Santerianumero1,
Can you check on the OpenVPN tab. There should be an option for Mobile OpenVPN using the latest firmware.- JamesGLMar 05, 2017NETGEAR Employee Retired
Hi Santerianumero1,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
