Santerianumero1
Jan 09, 2017Guide
R6700 Android VPN
I'm wondering why the KB article says it encompasses the R6700 but I still can't use my android with VPN and this router? I've tweeted you with no response either. Please help. https://twitter.com/...
- Feb 28, 2017
Hi Santerianumero1,
Can you check on the OpenVPN tab. There should be an option for Mobile OpenVPN using the latest firmware.
storm1985
Mar 05, 2017Prodigy
JamesGL if R6700 already support iOS or Android VPN client software can I request the following:
1. Update on the release notes of the firmware version that supports it. I cant see this on latest fw 1.0.1.16
2. R6700 manual update on page 169 which states it does not support mobile VPN.
These are only my suggestions. :)
Thanks.
JamesGL
Mar 09, 2017NETGEAR Employee Retired
Hi storm1985,
Checking with the team on your suggestions. Thank you for that. :)
Hi Santerianumero1,
You are welcome. :)
