Izkiz
Aug 16, 2020Tutor
R6700 bricked after firmware version 1.2.0.72
Hello... I update my router R6700v2 to the new firmware versión 1.2.0.72 and it crash my router. Is bricked and i can't acces to my router. I try everything on the internet, TFTP, and others solut...
- Aug 17, 2020
tftp has many steps that can fail.Make sure to follow exactly (even punctuation). there's even a video to watch to help see how its done.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
wcalifas
Aug 17, 2020Prodigy
What tftp method did you use? Did you download the program tftp2.exe to do it? If you tried a different way I suggest you use that tftp2.exe program to do it. Try pressing the reset button for a second or two and run the tftp right after you press it.
Izkiz
Aug 17, 2020Tutor
yeah, i use tftp2.exe, cmd tftp, tftpd64 and nothing... i press the reset boton, i try to connect my router with static ip and sending ping to default gateway and no connection...
i don't know what to do, i just accept a netgear update and my router crash...
- plemansAug 17, 2020Guru - Experienced User
