Izkiz
Aug 16, 2020Tutor
R6700 bricked after firmware version 1.2.0.72
Hello... I update my router R6700v2 to the new firmware versión 1.2.0.72 and it crash my router. Is bricked and i can't acces to my router. I try everything on the internet, TFTP, and others solut...
- Aug 17, 2020
tftp has many steps that can fail.Make sure to follow exactly (even punctuation). there's even a video to watch to help see how its done.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
Izkiz
Aug 17, 2020Tutor
i only can unlock 2 type of leds
1- when the router is off, i press the reset button for 30 seconds and i turn on the router... the power led start at color amber /orange and the port of my computer white, then all ports leds off and power led star blinking in white.
2- when i restart normally my router, the power led in orange / amber and my pc port in white.
michaelkenward
Aug 17, 2020Guru - Experienced User
Sorry, it still isnlt clear to me.
Let's keep this really simple.
After you have turned the thing on and it has finished the startup cycle, what does the power LED look like? That's the one on the top on the left.
What colour is it? White or amber?
Is it solid or blinking?
The rest don't matter at this stage.
