Wahe
Jan 06, 2022Tutor
R6700 Disconnecting periodically.
Logs below. Modem is SB8200, Router is R6700v2. Disconnects seem to not happen when wired in to the modem directly. Already power cycled, downgraded the firmware (and updated the firmware) and facto...
- Feb 11, 2022
Esch wrote:Hitting the exact same issue. Same configuraiton, modem, router.
Any additional suggestions?
Sadly, no. I tried everything I could think of outside of buying a new router.
Recently, it was fixed. Lease Obtained on the modem settings is now set to 4 days and when it renews it doesn't drop internet. I didn't do anything to change this, so I can only assume it was on Xfinity's side and they finally fixed it.
Jan 06, 2022Guru - Experienced User
Doea the Internet LED on the reouter change color when this happens?
Ensure the LAN cable between the modem and router is of good quality. CAT6 is recommended.
After you factory reset the router and setup from scratch, have you powered OFF the ISP modem for 1 minute then back ON?
- WaheJan 08, 2022Tutor
FURRYe38 wrote:Doea the Internet LED on the reouter change color when this happens?
LED changes to solid amber
Used CAT6, CAT5e (came with the router)
Powered off both, same result.
