Wahe
Jan 06, 2022Tutor
R6700 Disconnecting periodically.
Logs below. Modem is SB8200, Router is R6700v2. Disconnects seem to not happen when wired in to the modem directly. Already power cycled, downgraded the firmware (and updated the firmware) and facto...
- Feb 11, 2022
Esch wrote:Hitting the exact same issue. Same configuraiton, modem, router.
Any additional suggestions?
Sadly, no. I tried everything I could think of outside of buying a new router.
Recently, it was fixed. Lease Obtained on the modem settings is now set to 4 days and when it renews it doesn't drop internet. I didn't do anything to change this, so I can only assume it was on Xfinity's side and they finally fixed it.
Esch
Feb 11, 2022Aspirant
Wahe
Feb 11, 2022Tutor
