DesertShaqtus's avatar
Jun 04, 2021
R6700 dropping internet - amber/orange light on internet light
A few weeks ago my internet connection has started to drop periodically (10-12 times per day, sometimes hours between, sometimes within 20-30 minutes, no clear pattern). Connection is usually out for...
  • plemans's avatar
    Jun 05, 2021
    If its happening 10-12x a day, simply direct connect a pc/laptop to the modem and use it/stream on it. see if it stays stable.
    Easy way to determine if the isp was correct or not.
