leetol
Mar 13, 2017Initiate
R6700 Fails to Update Firmware or QoS over Internet
My R6700 is on firmware V1.0.1.16_10.0.30 which I had to manually update. When I try to use the update functions in Administration or the QoS screen, it states - "Attempting to connect to Netgea...
- Mar 22, 2017
Hi All,
Try to reset the router to factory default and manually reconfigure it. Check if the same problem after the reset.
michaelkenward
Mar 14, 2017Guru - Experienced User
No answer, I'm afraid, but yours is one of a series of similar messages that I have seen here over the past few weeks.
For example:
R6900 after firmware updated, no internet connecti... - NETGEAR Communities
One user even complained that the problem was with Netgear's updfate servers, but everyone else could get there, so that can't be the issue.
