leetol
Mar 13, 2017Initiate
R6700 Fails to Update Firmware or QoS over Internet
My R6700 is on firmware V1.0.1.16_10.0.30 which I had to manually update. When I try to use the update functions in Administration or the QoS screen, it states - "Attempting to connect to Netgea...
- Mar 22, 2017
Hi All,
Try to reset the router to factory default and manually reconfigure it. Check if the same problem after the reset.
mcseprofession
Mar 18, 2017Aspirant
Im on the model R8000 with the latest firmware at the moment V1.0.3.36_1.1.25 and I have the same problem.. I didnt have this problem until I upgraded.. I even switch to DDWRT for a few weeks for the QOS control and just switched back and still same problem.
- JamesGLMar 22, 2017NETGEAR Employee Retired
Hi All,
- JamesGLMar 26, 2017NETGEAR Employee Retired
Hi All,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
