leetol
Mar 13, 2017Initiate
R6700 Fails to Update Firmware or QoS over Internet
My R6700 is on firmware V1.0.1.16_10.0.30 which I had to manually update. When I try to use the update functions in Administration or the QoS screen, it states - "Attempting to connect to Netgea...
- Mar 22, 2017
Hi All,
Try to reset the router to factory default and manually reconfigure it. Check if the same problem after the reset.
JamesGL
Mar 22, 2017NETGEAR Employee Retired
Hi All,
JamesGL
Mar 26, 2017NETGEAR Employee Retired
Hi All,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
