Mark_53
Dec 06, 2017Star
R6700 Firmware update kills router
I tried to update per the insturctions sent 12/1/2017.R6700-V1.0.1.36_10.0.40 except I did it over a wireless connection and now I cannot communicate to the router even when directly connected throu...
- Jan 06, 2018
After trying a TFTP update with a Netgear Support agent, I was given an RMA to return the unit which I did. That should solve the problem.
RegisterAgain
Jan 06, 2018Aspirant
The latest update has made my R6700 router unreliable wifi wise, any cure available?
michaelkenward
Jan 06, 2018Guru - Experienced User
Different hardware, but you might want to try this:
Solved: Re: R6400 router slow after firmware update V1.0.1... - NETGEAR Communities
It has worked for others.
