drknute
Jun 24, 2018Aspirant
r6700 firmware upgrade failure 109
I get the following message while trying to perform the version 1.0.1.48_10.0.046 upgrade ' unknown error: 109'. I log on to my router and click the purple 'upgrade availble ' button, the file succes...
- Jun 25, 2018
The manual update process worked. Thank you very much for your help. Previously is connected through a hardware connection using a MOCA network. I'm surprised that it makes a difference.
Thanks Again
Drknute
Blanca_O
Jun 24, 2018NETGEAR Employee Retired
Hi drknute,
Welcome to NETGEAR Community!
Is the device connected wired or wireless?
Have you tried a different browser?
You may also manually update the firmware of the router. Here's a reference link: https://kb.netgear.com/23960/
Blanca
Community Team
- drknuteJun 25, 2018Aspirant
Thanks Again
Drknute
- Blanca_OJun 25, 2018NETGEAR Employee Retired
Hi drknute,
Thank you for your feedback. Glad that it's working now.
Blanca
Community Team
