pc2k17's avatar
pc2k17
Prodigy
Jul 24, 2021
R6700 goes offline
Just picked up the R6700v3 Nighthawk AC1750 Smart wifi router 5 days ago. Every day, at least once a day, it goes offline. It appears as if all ethernet, and 5 ghz connected devices lose internet and...
  • plemans's avatar
    Jul 24, 2021
    I'd try the factory reset and reinstall. You can use the app for setup.
    If that doesn't help, then try version 1.0.3.66 of the firmware. Install that, do a factory reset, then install it again and disable auto-updates.
    the newer versions have netgear armor and I've seen a few that didn't play nicely with it.
    Is it a new purchase? If so, you've got 90 days of free support from netgear (from date of purchase).
    You can click on "mynetgear" at the top. register an account and the device. From there you should be able to check warranty/support status.
