juduking
Feb 20, 2018Aspirant
R6700 I just upgraded my internet speed to 300mbps and not getting that when speedtesting
I have set the proper download speed in the settings on the router, it shows my new download speed at 321mbps, and the new upload speed is correct, but when I do a speed test check on my PC and my xb...
- Mar 03, 2018
I figured it out, so you can close this thread if you want.
Problem 1: I was running all Cat5 cables, so that was the first bottleneck. I bought all cat6 cables and things are running fine for my Xbox one and PS4.
Problem 2: My lan port on my PC was 10/100 only, so I needed to buy a new ethernet card. That fixed the bottleneck to my PC along with the cat6 cable.
All is well and working as intended now. Thank you again for the troubleshooting help.
