bigrosh
Oct 05, 2021Aspirant
R6700 keeps rebooting randomly
All of a sudden last week, the router kept dropping connection. I updated the firmware, did multiple reboots, did a factory reset, and it still drops connection as it tries to reboot itself. Someone ...
- Oct 08, 2021
bigrosh
Oct 07, 2021Aspirant
I tried researching on how to do this but was not successful.
If you can share the file of a prior version that i can upload into the router portal, that would be great.
Oct 07, 2021Guru - Experienced User
FW files for you v3 model are here:
https://www.netgear.com/support/product/R6700v3.aspx#download
- plemansOct 07, 2021Guru - Experienced User
Try using the 1.0.4.106 version. I've heard but the .118 and .120 have a dns issue.
- bigroshOct 07, 2021Aspirant
Thank you that is great to know!
Can you tell me where to upload the older version? I tried doing it under Backup but it said it failed. See screenshot
- plemansOct 08, 2021Guru - Experienced User
Did you extract it prior to trying to upgrade it?
- bigroshOct 08, 2021Aspirant
What do you mean extract? I saved the actual file within the zip file on my desktop and then uploaded that file and it resulted in failure. If you can guide me on how to extract, that would helpful.
