bigrosh
Oct 05, 2021Aspirant
R6700 keeps rebooting randomly
All of a sudden last week, the router kept dropping connection. I updated the firmware, did multiple reboots, did a factory reset, and it still drops connection as it tries to reboot itself. Someone ...
- Oct 08, 2021
Oct 08, 2021Guru - Experienced User
Did you extract it prior to trying to upgrade it?
bigrosh
Oct 08, 2021Aspirant
What do you mean extract? I saved the actual file within the zip file on my desktop and then uploaded that file and it resulted in failure. If you can guide me on how to extract, that would helpful.
- plemansOct 08, 2021Guru - Experienced User
when you dowload it, if you're in windows, simply right click and "extract all". Then use that file for uploading.
