sanjayG
Aug 07, 2022Follower
R6700 limiting speed
Hello, Recently updated internet speed to 300 mbps, service provider ran a fiber cable into the house and put a small modem, at the modem I get 300+ Mbps, modem to router is a high speed ethernet ca...
Aug 07, 2022Guru - Experienced User
I'd start with a factory reset and then test the speeds in its default configuration.
When you do go through setup, make sure to leave qos, access control, parental controls, and traffic monitoring all disabled.
