JoeOtt
Dec 26, 2017Star
R6700 Losing ability to connect at 2.4Ghz
I have an R6700 with the latest firmware (.36) on it. What has started happening since the last update is I will notice that all 2.4Ghz connections will drop off the connection list on the router. Th...
- Jan 28, 2018
Have not had a reoccurrence of the issue since the hot fix. Looks like it resolved the issue.
Zrgj
Dec 27, 2017Aspirant
Same issue.
JoeOtt
Dec 27, 2017Star
So after much frustration and no help from Netgear I installed dd-wrt. Works like a charm.
- ZrgjDec 28, 2017AspirantJoe - how long have you been using dd-wrt without it needing a reboot?
- JoeOttDec 28, 2017StarAbout 2 days. Still Rock solid
Mine was dropping every few minutes yesterday.
This morning, I turned off the 2.4 GHz guest network, and it hasn't dropped since. Of course, this is of some inconvenience to the guests we have this week.It's so frustrating to have a higher-priced router that has begun to behave like a $19.99 Amazon special. :(
