JoeOtt
Dec 26, 2017Star
R6700 Losing ability to connect at 2.4Ghz
I have an R6700 with the latest firmware (.36) on it. What has started happening since the last update is I will notice that all 2.4Ghz connections will drop off the connection list on the router. Th...
- Jan 28, 2018
Have not had a reoccurrence of the issue since the hot fix. Looks like it resolved the issue.
Zrgj
Dec 28, 2017Aspirant
Mine was dropping every few minutes yesterday.
This morning, I turned off the 2.4 GHz guest network, and it hasn't dropped since. Of course, this is of some inconvenience to the guests we have this week.
It's so frustrating to have a higher-priced router that has begun to behave like a $19.99 Amazon special. :(
JoeOtt
Dec 28, 2017Star
I did try that. No love. Got my guest network back with Dd-wrt
- ZrgjDec 28, 2017AspirantI also turned off auto-select on the channel number for the 2.4 GHz band. Maybe that had something to do with it.
I've used dd-wrt before. Just kind of lazy today. 😁- HWAMDec 29, 2017ApprenticeSame issue as a lot of R7000 owners have. 2.4GHz Wi-Fi devices are loosing their connection. Netgear can't fix it. The newest firmware are ruining the routers. Even a downgrade and reset is not fixing the problem. They tried to fix it with 2 beta firmwares but without success. Just buy another brand and forget Netgear.
- ZrgjDec 29, 2017Aspirant
Seems that they are ignoring requests here, on Facebook, and on Twitter.
I'm almost ready to flash with DD-WRT. I'll avoid Netgear in the future, for sure.
- JamesGLJan 07, 2018NETGEAR Employee Retired
Hi All,
Please try this firmware. If same problem, report with your observation.
https://kb.netgear.com/000053180/R6700-Firmware-Version-1-0-1-38-Hot-Fix
- JamesGLJan 11, 2018NETGEAR Employee Retired
Hi All,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.- klpetersJan 11, 2018AspirantI installed the hot fix last night. So far everything is working fine. Will give it another day or two to see if we are in the clear.
