JoeOtt
Dec 26, 2017Star
R6700 Losing ability to connect at 2.4Ghz
I have an R6700 with the latest firmware (.36) on it. What has started happening since the last update is I will notice that all 2.4Ghz connections will drop off the connection list on the router. Th...
- Jan 28, 2018
Have not had a reoccurrence of the issue since the hot fix. Looks like it resolved the issue.
Zrgj
Dec 28, 2017Aspirant
I also turned off auto-select on the channel number for the 2.4 GHz band. Maybe that had something to do with it.
I've used dd-wrt before. Just kind of lazy today. đ
HWAM
Dec 29, 2017Apprentice
Same issue as a lot of R7000 owners have. 2.4GHz Wi-Fi devices are loosing their connection. Netgear can't fix it. The newest firmware are ruining the routers. Even a downgrade and reset is not fixing the problem. They tried to fix it with 2 beta firmwares but without success. Just buy another brand and forget Netgear.
- ZrgjDec 29, 2017Aspirant
Seems that they are ignoring requests here, on Facebook, and on Twitter.
I'm almost ready to flash with DD-WRT. I'll avoid Netgear in the future, for sure.
