JoeOtt
Dec 26, 2017Star
R6700 Losing ability to connect at 2.4Ghz
I have an R6700 with the latest firmware (.36) on it. What has started happening since the last update is I will notice that all 2.4Ghz connections will drop off the connection list on the router. Th...
- Jan 29, 2018
Have not had a reoccurrence of the issue since the hot fix. Looks like it resolved the issue.
JoeOtt
Dec 28, 2017Star
I did try that. No love. Got my guest network back with Dd-wrt
JamesGL
Jan 08, 2018NETGEAR Employee Retired
Hi All,
Please try this firmware. If same problem, report with your observation.
https://kb.netgear.com/000053180/R6700-Firmware-Version-1-0-1-38-Hot-Fix
